PostPosted: Wed Mar 09, 2016 9:50 am
Hi, guys!
I want to use ST for FM broadcasting. The sound I want to achieve is something like Zenith preset in Breakaway Broadcast or better than that.
The sound got to be: clean, opened, soft and loud. Not too much highs and bass. Something like well produced original songs, but... loud.
Can you help me with this?
Thank you!
PostPosted: Fri Mar 11, 2016 1:23 pm
Try 7 wonders for starters. I prefer Unreal or Diggy Down, but those two differ much from Zenith.
PostPosted: Fri Mar 11, 2016 1:34 pm
Thanks!
PostPosted: Sun Dec 02, 2018 4:26 pm
Where do you find the presets? I'm using the Basic license. Which upgrade(s) to I need?
