Site Admin |
Hello Barry,
Grayed out means that the filter to which they belong is switched off. Load a preset, and then you can use them do make some (big) changes to the sound.
For speech: I've made a microphone processing preset which will be available in the next beta version and release. It was made to mimic the sound of a Symetrix and Airtools (I had original recordings and processed versions for both processors and I've made something that's in between). Not sure if it's suitable for what you're looking for but it could be a starting point.
I expect to be able to post the new beta (752-BETA025) in about an hour.
