PostPosted: Sun Jul 27, 2014 10:12 pm
So, I have started using 7.44 under Windows, and noticed the Normal Output section has an odd new dropdown. I'm not sure which setting I want to use--the Normal Output is going directly to the AM Transmitter. All pre-emphasis, HPF, etc is done using ST so I need to entire processed output...
Which one do I pick?
PostPosted: Mon Jul 28, 2014 12:32 am
Just leave at default. It shouldn't do anything anyway if FM output is not used.
Btw: I would advise to use FM output for this because it contains tilt correction!
