Of course, with the setup you have now you'll never reach really good quality. After all, you're broadcasting a copy of a copy of a copy, with FM processing, pre-emphasis and bad reception in each step.
That is what i am talking...
if i understend him .. Sound from mixer goes to dbx .. then to transsmiter1 (with hardware stereo coder) then Tuner1 with stereo out and on another stereocoder and to transmitter2 .. now tuner2 with stereo output and in Juli@. He again says that he don't use mpx from ST so... stereocoder No.3.. and then Final.... main transsmiter. Even if he use mpx from ST will not help.
this way ..
- the best Stereo coders will turn around phases, shange levels ..etc..3 times in 3 ways ..
- tuners .. x3 .. what .. noise?!.. at -15
- listener's tuner is 4th. tuner..
again:
Mixer (balanced Out) > (balanced in) dbx (balanced out) > (balanced in juli@)pc with ST (mpx out from juli@) > transmitter1 > reciver1 > transmiter2 > reciver2 > Main Transmitter (Where both recivers have MPX out used for transmitters input).
- Like this you totaly avoid to use your hardware stereocoder(s).
- PC is at your studio (easy for control)
- MPX from Stereo Tool and Juli@ (which is better then hardware stereocoder) is not going thru 3 stereocoders.
So, you request answer how to transfer signal from studio and not to give a 1$ .. and this is answer and the much better way.
note: if your tuners not have mpx out, you can make them to have or someone who knows little abput electronics to make for you. (like i do for my tuner).
