PostPosted: Thu Aug 01, 2013 3:17 pm
Hello All,
I am somewhat new to Stereo Tool. I am using it in an attempt to enhance the sound of my Web radio broadcasts. I use it with SAM Broadcaster, stream at 128K via Spacial Audio. I play a variety of music, mostly classic rock, but a few oldies and country thrown here and there. Can anyone recommend a good preset to use for this, or possibly suggest a download that an experienced user has created for this purpose? Does anyone have any experience with using it in SAM, and if so, do you also use the SAM AGC module adn/or EQ with this as well?
Thank you in advance for your time!
MarkD - Texas
PS: I will be on the air tonight on JDX1029.COM starting at 6:30 Central Time - I will be using Stereo Tool to process my sound. I want to have the best sound on the station!
PostPosted: Fri Aug 02, 2013 12:38 am
Definitely turn off any processing in SAM! Then I would just try out the presets and see which one you like...
PostPosted: Fri Aug 02, 2013 3:49 pm
Thank you! I will turn everything off and do some testing. I have a test stream set up now so I can listen as if I were on the air.
