Your example essentially says that 100% of the dB-changes are corrected per second.
No, that's what happens per sample. However since the difference is reduced at each sample it slows down quickly!
However that would be much too fast because speed increases (linearly?) with greater distance from target.
That is correct. But as I said, the difference decreases with each step. So the speed drops rapidly. Which is usually exactly what you want (you don't want to HEAR it drop over a longer period of time).
So maybe I should divide by the maximum distance to make it the maximum speed or by half the maximum distance to make it fit on average?
That's too much. Have to think a bit here....
