Hey,
I am using this preset for -12 LUFS:
viewtopic.php?f=10&t=33345
BigFlex 6 v.029
with StereoTool 9.92 (Winamp Plugin for RadioBoss). I normalized all tracks with -16 LUFS (would you recommend this value?)
Now I notice on air that the sound is pumping. I am not a pro with StereoTool, so I have no clue where I can change the settings to avoide this kind of pumping.
I have enabled "show deprecated settings", but honestly don't know if everything is fine with this. Maybe this preset doesn't work so good with 9.92?
Can really use help, appreciate every answer - thanks
