 Post subject: Microphone Trouble
PostPosted: Fri Mar 03, 2023 6:19 pm
OK so I've sorted the mixer problems out and everything works as it should. I'm now having trouble with the Microphone [Behringer C-1 XLR]. While the music is coming out strong, when I open the mic the music overpowers my voice, even when I use the faders on the music. I'm not sure why or what I'm doing wrong? If anyone can help that would be fab :)
Jason
 Post subject: Re: Microphone Trouble
PostPosted: Mon Mar 06, 2023 1:29 pm
Jason
Do you use the speech detection mode at all?
Not sure if this needs BIMP.
I am sure one of the more experienced members here will comment.
I'd be interested to see how you get on, as I am planning to add radio scheduling software (Rivendell), a mixing desk and a microphone at some point in the future.
PostPosted: Wed Mar 08, 2023 5:38 pm
I haven't tried the speech detection yet. I too was wondering would I need the BIMP. However, the BIMP only seems to be available on Input 2. I'll do some more testing and let you know.
PostPosted: Thu Mar 09, 2023 10:22 pm
Great! Let me know how you get on with speech detection as the first step, unless a more seasoned member here comes up with some solutions.
PostPosted: Mon May 15, 2023 5:40 pm
The BIMP is the solution for this; you want your microphone input to be processed and at a specific constant level before you mix it in with the music. But that does indeed require that you can feed the microphone signal from a different input, so it needs to bypass the (hardware) mixer; there is a software mixer in Stereo Tool though which you could open on a tablet for example.
PostPosted: Tue May 16, 2023 1:04 pm
I can certainly do this. I will give this a test.
