If wanting a relatively transparent sounding preset, consider trying the older Bojcha 7 Wonders preset as a baseline. Take a look at the waveforms. Gain aside, the input and output waveforms usually look quite similar, at least in my limited testing*.
Control the output volume with the simple clipper, or alternatively enable advanced clipping and up the clipper driver for a louder sound if desired. If highs seem a little diminished or somewhat flat with the advanced clipper enabled, try turning on "softer and duller but less grainy" under the advanced clipper's sound menu.
*I use ST mostly for personal audio processing, not broadcasting, usually with my own configuration so YMMV.
