PostPosted: Mon Oct 01, 2018 1:37 am
Recently purchased, thank you! Using ClaveFremen's guide for initial settings: https://www.diyaudio.com/forums/pc-base ... s-war.html
I am using the 64bit VST plugin in JRiver Media Center 24. Is there a way to get full screen as the VST GUI is cut off and I can't find a setting like that anywhere.
Where do I set the threshold for the declipper and natural dynamics to kick in?
In JRiver, I have the VST set to "process independently of internal volume", as I use the internal digital volume control to control music playback volume.
Having spent 10 years as a recording/mixing engineer and being guilty myself of overly compressed/limited music, these algorithms sound really good to my ears. Thanks!
Link to the saved settings from Crave's diyAudio article linked above: https://tsiwest.blob.core.windows.net/u ... ttings.dcl Any feedback would be great.
Thanks!
Mitch
https://www.amazon.com/dp/B01FURPS40
PostPosted: Tue Oct 23, 2018 12:39 pm
Hit the configuration button and then look to the right under user interface and check the full screen option
PostPosted: Tue Oct 23, 2018 5:17 pm
Thanks. I must be missing something?
PostPosted: Wed Oct 24, 2018 11:55 am
I don't think the VST version has the full-screen option. Does the Stereo Tool VST plugin behave in the same way or is that displaying correctly?
PostPosted: Fri Oct 26, 2018 5:31 pm
Thanks for your reply. I am not sure what you mean. Is there another VST I should try or be using? If so, where can I download it and will my existing license work?
PostPosted: Mon Oct 29, 2018 9:38 pm
You might change it to Expert mode. Then you should be able to check the setting for Full Screen.
Three Decades of Country!
PostPosted: Mon Oct 29, 2018 11:30 pm
Declipper actualy does not have classic threshold. It always chase peek level no metter how much is it - so kinda auto. You have "detection" tho, and it's already on good default settings.
Same applies for ND too.
PostPosted: Tue Oct 30, 2018 2:30 pm
Just for testing please try the Stereo Tool VST plugin which you can download from our website. Please let us know if that is displaying correctly.
There is no full screen option in VST plugins, neither does the declipper plugin have an operating mode setting.
