 Post subject: auto eq tutorial
PostPosted: Sat Jun 02, 2018 2:51 pm
The plugin you make is great the only issue I have is that there are no real video explaining on how the auto eq actually operates. I saw the video where you just toggle the auto eq on and off. but you don't go more into depth on how to adjust the sliders. Recommendation is that you make presets you can load for different music types (Dance, Hip Hop, RnB, Rock, etc). If someone on your end could create a starting point then could be easily adjusted from there. I also attach a link to a mix I made and the style of music I'm trying to auto eq.
I would sincerely appreciate any help I could get. Thanks
https://www.4shared.com/music/_cnXBvlre ... p_143.html
 Post subject: Re: auto eq tutorial
PostPosted: Thu Dec 13, 2018 12:27 pm
WOW over 1100 looks but no responds[img]
PostPosted: Thu Dec 13, 2018 2:09 pm
AutoEQ shouldn't really need specific settings for specific types of music. It's goal is to balance the spectrum to correct for too loud or too little bass / mids / highs and whatever you define in between. If the median display is enabled you'll see white dotted lines in the AutoEQ display showing the median value of its adjustments. These lines should be somewhere near the 0dB mark (after it has seen a few hours of material), because that means on average it does nothing.
AutoEQ helps to make the sound consistent before it hits the compressors, making it easy to get consistency even with little compression.
