 Post subject: File Polling Help please
PostPosted: Fri Jun 05, 2015 11:55 pm
Hi All
Looking for some help please
I used to use Samcast which contained filepoller which I used to pick up the last line of history from Virtual DJ8 and display in the player ie winamp or website players etc
I now use Edcast with the modded settings which sounds great which i see i can manually update metadata or pick up a file, prob is this only picks up the first line of the vdj history if pointed at that file
I see file poller listed on my licence on ST, is there a way i can show the song titles im playing while using edcast and ST
Hope that makes some sense
Thanks in advance for any help
Matt
PostPosted: Sat Jun 06, 2015 9:46 am
File polling in ST is to read presets. And RDS can read from a file. But that's it, no communication with Edcast there...
