PostPosted: Sat Feb 17, 2024 1:05 am
is there any settings where i can control the release and attack? greetings
the problem is he builds up to slowly. if he is build up he do his job great. but the build up time takes to long. in the meanwhile a other instrumente starts playing^^
i m a german guy and the translation to german is awefull. kind be hard for me to set the settings if i dont know the words in english xD
i can try set the settings hard to max. so he is everytime up 100% but i think thats not a good idea and not so good for the music
PostPosted: Fri Mar 22, 2024 7:58 pm
Yes! The setting is right beside Bands, and is called "Responsiveness". Click the dropdown and hit the settings button to see them.
You have Adjustment time (defaults to 0.7 seconds)
Acceleration at sudden gain jumps (defaults to 3.4
RMS Size (which is probably going to affect release?)
Reduce Boosts at sudden jumps (per band) above 6dB (default is On)
Legacy Attack (default is On)
