PostPosted: Sat Jan 15, 2022 5:51 pm
Hello, I'm new to Stereo Tool and trying to understand where the "Makeup Gain" control is located for the two Multiband compressors. For example, with the Multiband compressor engaged I'm seeing a -3 to -6db gain reduction on the meters. I simply want to makeup that gain before going to the next stage. With other compressors like TDR Kotelnikov the Makeup Gain control is next to the Output Gain control. Is this setting somewhere else within the Multiband compressor menus or does Stereo Tool use a different name for makeup gain?
Thanks in advance!
PostPosted: Sat Jan 22, 2022 1:09 pm
Density and/or Drive
PostPosted: Mon Jan 24, 2022 4:30 am
Thanks Bojcha for your help. I'm using these controls now with the understanding that they serve the "makeup gain" purpose.
