PostPosted: Sat Jun 16, 2018 8:02 pm
Which settings in the free version do I need to disable to not get the process by stereo tool message every so often??
Phat Beats Radio Playing the best Rap RnB Soul Funk Reggae Chillhop Acid Jazz Triphop Blues from the 70s to early 2000s streaming at 192kbps Opus over 165k tracks in the playlist
PostPosted: Wed Jun 20, 2018 1:46 am
Good question. Here's a list I got from the developer himself, HVZ.
Declipper
Delossifier
Natural Dynamics
Auto EQ
Bass EQ
Advanced Clipper
all FM stuff
BIMP (new in 9.10, built-in microphone processor)
Note with Declipper and Delossifier there is a beep every few minutes and not the processed message. Those you *have* to disable unless using StereoTool for less than a minute or two at a time live.
Another thing, when you change presets, the enabled features for the specific preset change. So after you select your desired preset that's a good time to check which features need to be turned off. For me what works is selecting a standard preset not an FM one, that way the FM stuff's already off by default.
Lastly using Simple Clipper in place of Advanced Clipper can give you some clipping to make the sound louder. Simple isn't as good as Advanced but still works decent.
HTH and thanks Hans!
