Hi!
I use StereoTool at my transmitter site, the feed is coming through an Icecast stream. Because the internet connection at the tx site is unstable in some cases, I need a large buffer size. Currently I play the 320kbps mp3 stream with Winamp to Virtual Audio Cable, which is then processed by ST. I set 512KB buffer size in Winamp's MPEG decoder. It's give me ~13s latency.
But the problem is with this 'solution': the buffer size is changing over time, so the latency is not fixed!
Sometimes only a few seconds, sometimes a minute...
I saw that the Breakaway One has a great solution for this: I can set the desired buffer time in the stream receiver section, and the program is continously monitoring the buffer size, and -if needed- it change a bit the playback speed.
I don't want to buy the Breakaway One, because I have a full FM license for ST.
Can I do this with ST's integrated VLC? Or it's a premium feature that only expensive hardwares can do? (except BAO...)
Unfortunately, I didn't see the stream buffer size adjustment slider in the input section of ST, but maybe I'm blind...
Thank you!
