PostPosted: Fri Jun 30, 2017 3:52 pm
Hello.
I use ST through DSP in Winamp. After a PC reboots, the default preset is loaded.
How can I make my preset load automatically after reboot (ST loads itself with default settings)? I always load it manually, but it is hard to know, when PC was out of electricity.
Thanks,
Andreas
PostPosted: Wed Aug 16, 2017 11:25 am
It should automatically reload the last used preset, BUT it only saves it when you:
- Minimize it
- Close it
- Save a preset
So, if you select a preset and then the power goes out, it will forget that you ever selected it.
