Thanks for your answer Hanz,
Between time, I dropped wimamp for AIMP always with the ST plugin dll, and it's better. Don't ask me why, but winamp don't evoluate since 10 years. AIMP is still followed.
If someone can test and confirm ?
To store the title song from the stream locally in C:\OnAir.txt for the RDS, I use 'Current track into to file' plugin
Regarding your anwser Hans and the right splitting, for the moment the ST_plugin has only FM output and transmitter activate with non option and send to the main ST. In the main ST, Dequantizer and Delossifier are activate in Repair section. Do I need to set these 2 option in the ST_plugin and no more in the ST main ? Is it better ?
The goal of the tutorial section in the forum is to help you if we can also post into
