 Post subject: Presets
PostPosted: Tue Nov 15, 2016 4:24 am
Why are most of the presets suffixed with (soft)?
What's the meaning?
I just use ST Winamp to listen to music.
 Post subject: Re: Presets
PostPosted: Tue Nov 15, 2016 10:42 am
Those are the Generic versions, where all loudness-stuff is disabled.
PostPosted: Tue Nov 15, 2016 6:40 pm
Holy crap, I've just realised what you mean!
They're all listed again in the next section, but with loudness enabled.
Don't I feel stupid.
PostPosted: Tue Nov 15, 2016 8:07 pm
OK, but I still can't figure out what to change in the GUI (I'm using the Winamp/DSP version in Extreme Tweaker Mode, with Depreciated Settings shown) to get the difference between the two.
i.e. if I load up the (soft) version of your Unveil Mod Hans, no matter what I do I can't get the same loudness as when I load the Preset from the Web/DAB/HD Radio stations section.
I've looked at the two STS files with a diff viewer, the big thing that's changing is
[Final Limiter]
Pre-amp=0.400000006 / 1 (0.4 is in the soft version, 1 in the loud version)
I can't see anywhere in the GUI where that Pre-amp is adjusted.
Am I stupid? :)
PostPosted: Wed Nov 16, 2016 4:26 am
Figured it out...
It's called Final Limiter in the config file, but it's the "Simple Clipper" section :)
PostPosted: Tue Nov 22, 2016 11:28 am
Heh :) names in the .sts file are old since I cannot change them. If you look at the old compressor, it even starts at band -1 (because Stereo Tool 1.0 had 8 bands, and in 2.0 I added 2 at the bottom).
