 Post subject: DigDis: In The Mix
PostPosted: Tue Jun 16, 2015 4:22 pm
nothing more to say than just listen! This is my present called "trance-parent". It is based on diggy_down15c and the diggy_down within stereo tool 7.70.
You will find all the streams here:
http://dir.xiph.org/by_genre/Digdis
 Post subject: Re: DigDis: In The Mix
PostPosted: Tue Jun 16, 2015 7:34 pm
Dead links.
PostPosted: Tue Jun 16, 2015 10:02 pm
Dead links.
Thanks for noting that. Updated the links, so now it should work better!
PostPosted: Thu Feb 09, 2017 1:50 pm
The link doesn't work...
