PostPosted: Sun Jun 05, 2016 10:55 am
Hello, someone who is using a plate ESI Juli @ can give me the values of tilt correction established ?.
I own this board but I lack a modulation monitor to adjust.
So I guess an approximate value is better than nothing :)
Thanks
PostPosted: Mon Jun 06, 2016 4:12 pm
Depends on the transmitter. Values that have worked for me are between +50000 and +100000 microseconds.
PostPosted: Tue Jun 07, 2016 3:30 am
RC 2 uses the same RC?
Thank you very much for you help :)
PostPosted: Sun Jun 19, 2016 8:45 pm
+23,300 for me. I think it varies for different setups.
- Best of luck.
:geek:
