 Post subject: 1U Pre-built PC's for ST
PostPosted: Fri Apr 22, 2016 8:46 pm
If anyone is looking for a place to order custom pre-built PC's for ST, here is a company in the US that specifically builds rackmount PC for broadcasters, the 1U model in the link below would be particularly helpful.
http://www.proracksolutions.com/products/istream/
Per Hans' recommendations, for full functionality Core i5 is recommended, but will also run on Core i3. As mentioned in the sound card section, the ASI 5810 would pair very nicely with one of these boxes, and support full 192Khz sample rate for full FM output.
http://www.audioscience.com/internet/pr ... si581x.htm
-Matt Levin
PostPosted: Sat Apr 23, 2016 4:58 am
Price?
PostPosted: Sat Apr 23, 2016 3:41 pm
Price?
Not easy to find prices since a lot of the so called distributors have no information on their website about this product.
While the product looks promising with it's available PDF Data I would like to see some reviews and fixed prices before considering a purchase.
PostPosted: Mon Apr 25, 2016 5:35 pm
The price for the ASI 5810 card averages around $550, depending on which distributor you purchase it from. This is the vendor I purchased mine from, so I know they sell them; http://bgs.cc/catalog/index.php
As for the PC's, it depends on how you configure the computer, you just have to call and spec on out. I believe that company will also purchase and pre-install the ASI card for you if you request it. They build automation PC's for DJB, so they are used to setting one up for use with a professional sound card. I may call them and setup a "recommended" configuration for Stereo Tool.
-Matt Levin
