PostPosted: Sat Aug 23, 2014 7:12 pm
Some time ago, when I fiddled with Windows 7, I noticed strange behaviour of threads in this OS. On multithreaded processors (or multicore processors), when you load only 1 thread, it seems to jump, using all of the available cores or threads. This was not the case when using Windows XP. I tried it numerous times with 64-bit and 32-bit versions of Windows 7 Home Premium and Professional, and even Windows 8.1 Update 1, as well as multiple processors from Intel and AMD and always got similar results.
You can try it for yourself - use prime95 or OCCT and try to load only 1 thread - it will not stick to one of the processor's threads or cores - it will jump all around the cores, only occasionally loading one of them significantly (it works also for 2, 3 threads etc).
When I did that on Windows XP, I was able to assign thread to a specific core. I didn't manage to do that in Windows 7 or Windows 8. For me it looks like a bug in the OS scheduler. It might possibly impact a performance of multicore CPUs, as you want to keep threads separate and not merged, especially when software, such as ST, uses only 2 threads of 4 or even 8 available. Maybe it could also affect usage of multiple instancies of ST.
Can someone comment on that?
Regards,
Slawomir.
PostPosted: Sun Sep 28, 2014 4:50 pm
CONFIRMED. I have exactly the same problem...
My radio station
http://amradio.ddns.net
PostPosted: Sun Sep 28, 2014 7:45 pm
That windows tries to be smart and trying to spread power over cores.
Once i asked Hans to make table in ST for that. W7 and (i think) W8 uses same hex table to determine what cores/threads you want to use.
Since ST uses 2 cores. in table like that you can select what cores you want to use.
For example. ST1 uses 1st and 2nd core out of 4, ST2 uses 3rd and 4th core.
You can also do that now.
Make shortcut (make new txt file and rename it to something.bat and put it in ST folder) for ST wich will have this line..
start /affinity c0 StereoTool.exe
This example is for to run stereotool.exe on 1st and 2nd core out of 8 cores.
How to find what to put instead "c0"
Go here, http://www.mathsisfun.com/binary-decima ... erter.html
In binary tab type "0" or "1" - for example if you have 4 cores and you want program to run on core 1 and 2 you should put "1100", wich gives hexadecimal result of "C". So line in bat file will be
start /affinity c StereoTool.exe
PostPosted: Mon Sep 29, 2014 5:01 pm
Next version will have core affinity settings built-in!
PostPosted: Mon Sep 29, 2014 5:04 pm
Great.......
My radio station
PostPosted: Mon Sep 29, 2014 9:22 pm
ok great.
However, what if i have 4 cores and 8 threads?
In table it should be shown as 8 but what to use. 2 threads or 2 cores witch is 4 threads.
I don't have such CPU to test that.
PostPosted: Mon Sep 29, 2014 10:29 pm
Good to know, will try this later :) I have hyperthreaded CPUs so I can try it, but my personal opinion is that Windows recognizes the cores and their hyperthreads, at least in Intel CPUs. Look at those:
http://i.imgur.com/Q2hY7sX.jpg - CPU usage ST, with main window visible (7.24)
http://i.imgur.com/JqriBzE.jpg - CPU usage, ST with main window hidden (7.24)
See the difference? Two main threads are visible as odd threads. While the second one looks like thread occupied by GUI (but I might be wrong). This is dual core, hyperthreaded (i5-3210m).
On the other hand, AMDs implementation of simultaneous multithreading is different: AMD FXes (Bulldozer, Piledriver) are modular, so that 8 core CPU, truly has 4 modules and 8 "cores", 2 of them per 1 module. Why "cores"? Because they share one FPU, so they are not full cores really. Windows is not aware of that the chip can effectively utilize only 4 out of 8 cores in total, when loaded with FPU hungry calculations. It happens that Windows assigns 8 FPU calculations (instead of 4) completely randomly, thus blocking the chip with FPU data.
That's why I sold this chip.
PostPosted: Sun Oct 05, 2014 12:46 pm
BTW I am testing windows 10 and the affinity problem seems to have been fixed.
My radio station
PostPosted: Thu Mar 26, 2015 2:11 pm
I know this goes back aways... But is there a way in Windows to see what all is using a specific core? The Task Manager is not detailed enough to show which process is using which core.
Three Decades of Country!
PostPosted: Tue Apr 07, 2015 2:30 pm
In Windows 8 you can have heatmaps for this:
http://superuser.com/questions/493827/w ... graph-only
