PostPosted: Sun Feb 04, 2018 7:08 pm
Much as I would like to run a Marian SERAPH card (their Trace series has ceased production) available funds just cannot justify. Is there any other 24-bit 192K internal cards with digital in/out?
I'm aware of the external USB's but would prefer internal.
Thanks.
PostPosted: Sat Feb 10, 2018 4:32 pm
there was one JULI@ XTE for sale on ebay recently. that has 192KHz on the analog outputs.
SPDIF thru toslink and RCA.
If you are lucky to find one, buy it! saw the one i mentioned for €80 which is a bargain.
there is the question, Why do you need the 192KHz? are you going to put out a composite MPX signal?
If Not, just settle for the ESI MAYA es https://www.thomann.de/gb/esi_maya44_ex.htm
PostPosted: Sun Feb 11, 2018 2:42 pm
Hi Marco,
The reason for 192K card is yes a composite output and on several forums I have read that one requires a 192K and not a 96K card.
Thanks.
PostPosted: Fri Feb 16, 2018 12:01 pm
Yes, 192kHz is a must for composite output. No other choice there. ESI Juli@ is decent. But I saw Trace Alpha being sold at Thomann, did you check there?
PostPosted: Fri Feb 16, 2018 12:49 pm
I did but the Trace Alpha is now no longer being produced by Marian.
In fact they have ceased production of all PCI sound cards. The SERAPH range are all PCIe and the AD2 is the one I think I'm going for.
PostPosted: Sun Feb 18, 2018 4:39 pm
That one sounds familiar. Big chance it ended up in my trashcan.
