 Post subject: best bitrate to use
PostPosted: Sun Oct 23, 2016 3:21 am
I am not sure what is the best bitrate to use as well what format as I have both mp3 and wma.
Memory /CPU or available space are non-issues I have adequate.
After my RAID5(an older HDD died :( ) failure last week I went to RAID10 with new HDDs.
Hopefuly I get a reply from Hans to my email
mapleleaf
 Post subject: Re: best bitrate to use
PostPosted: Sun Oct 23, 2016 11:05 am
mapleleaf
It's of course best to store your music losslessly (eg, wav or flac).
PostPosted: Mon Oct 24, 2016 11:59 am
I just replied.
DO NOT use MP3 or WMA or any other lossy format for storing music! The effect on the sound quality coming out of the processor is huge. Only use lossless, unless you can't get the audio in that format.
PostPosted: Wed Oct 26, 2016 9:46 pm
I just replied.
Thank you, I appreciate your reply/response
I am currently cataloging 1.3TB of music using for the large part TagRename something to keep me busy during the winter(snow has already fallen in the mountains or higher altitudes)
I am still trying to figure out why I am frequently getting artifacts at 4024 latency when at 1024 I am not.
In addition, I am not having issues using WMA looseless @1024
btw, with v8.12 I am seeing cpu usage 5%-7%
PostPosted: Wed Oct 26, 2016 9:48 pm
mapleleaf
Oddly enough, I dont have any flac files. Would you care to send me a sample?
PostPosted: Thu Oct 27, 2016 10:17 pm
Rip some CD, install dBpoweramp, compress to FLAC.
PostPosted: Fri Oct 28, 2016 6:37 am
If he has WMA lossless, what you're saying is useless (And, I think he mentions that). WMA is not only lossy but is also available in a lossless format.
PostPosted: Fri Oct 28, 2016 5:25 pm
Ah I didn't know that! Ok then.
