 Post subject: FM Generate Tones bug?
PostPosted: Sun Jun 12, 2016 10:21 pm
For some reason my Stereo Tool will not generate FM tones at all. Nothing happens. ST v 7.85; Windows 7; ESI Juli@. AISO in / out using FM output.
Anyone have any suggestions? If I have input playing; the tones do nothing (ie they dont start). If I stop audio input, then generate a tone..... nothing happens (no tones go out of soundcard outputs; even though they 'appear' to be working accoring to waveforms.
Thoughts?
PostPosted: Tue Jun 14, 2016 12:01 am
Is "FM Transmitter" enabled? I've never seen this not work... assuming that the necessary settings are enabled.
PostPosted: Tue Jun 14, 2016 2:37 am
Yes..... Been a user of ST many times. Ive experienced many bugs since installing this new Juli@ card. Even a fresh install of ST. Still not producing tones while the input is active.
