Hi Ricardo,
The behavior that you describe, especially the fact that you can't kill Stereo Tool (I assume you tried via Task Manager?) is very strange. I have seen behavior like that with some bad drivers. And there's always a possibility that Stereo Tool triggers it while BBP doesn't (there are also cases where the opposite happens).
I would suggest you to try ASIO, because generally the ASIO drivers appear to be better, you get less latency, and using input and output simultaneously is problematic without ASIO on some sound card drivers with some Windows versions. Using ASIO usually fixes everything.
