PostPosted: Fri Oct 23, 2009 2:19 am
This software looks amazing but unfortuantely I am yet to try it as a sweep of the lastest download 4.21 is detailling a virus from 2 scanners.
They both advise a Eldorado Ad Trojan and so at the moment I am VERY hesitant to install this software. :o
The full sweep from VirusTotal is shown below and I would love to hear back form the devs as this does look like a great piece of kit but I dont want to compromise my system if a virus is present.
Thanks in advance.
Col.
Antivirus Version Last Update Result
a-squared 4.5.0.41 2009.10.22 -
AhnLab-V3 5.0.0.2 2009.10.22 -
AntiVir 7.9.1.44 2009.10.22 -
Antiy-AVL 2.0.3.7 2009.10.22 -
Authentium 5.1.2.4 2009.10.22 W32/AdAgent.U.gen!Eldorado
Avast 4.8.1351.0 2009.10.22 -
AVG 8.5.0.423 2009.10.22 -
BitDefender 7.2 2009.10.23 -
CAT-QuickHeal 10.00 2009.10.22 -
ClamAV 0.94.1 2009.10.22 -
Comodo 2696 2009.10.23 -
DrWeb 5.0.0.12182 2009.10.23 -
eSafe 7.0.17.0 2009.10.22 -
eTrust-Vet 35.1.7080 2009.10.22 -
F-Prot 4.5.1.85 2009.10.22 W32/AdAgent.U.gen!Eldorado
F-Secure 9.0.15370.0 2009.10.22 -
Fortinet 3.120.0.0 2009.10.22 -
GData 19 2009.10.22 -
Ikarus T3.1.1.72.0 2009.10.22 -
Jiangmin 11.0.800 2009.10.22 -
K7AntiVirus 7.10.877 2009.10.22 -
Kaspersky 7.0.0.125 2009.10.23 -
McAfee 5779 2009.10.22 -
McAfee+Artemis 5779 2009.10.22 -
McAfee-GW-Edition 6.8.5 2009.10.23 -
Microsoft 1.5202 2009.10.23 -
NOD32 4535 2009.10.23 -
Norman 6.03.02 2009.10.22 -
nProtect 2009.1.8.0 2009.10.22 -
Panda 10.0.2.2 2009.10.22 -
PCTools 4.4.2.0 2009.10.19 -
Prevx 3.0 2009.10.23 -
Rising 21.52.34.00 2009.10.22 -
Sophos 4.46.0 2009.10.22 -
Sunbelt 3.2.1858.2 2009.10.23 -
Symantec 1.4.4.12 2009.10.23 -
TheHacker 6.5.0.2.051 2009.10.22 -
TrendMicro 8.950.0.1094 2009.10.22 -
VBA32 3.12.10.11 2009.10.22 -
ViRobot 2009.10.22.2001 2009.10.22 -
VirusBuster 4.6.5.0 2009.10.22 -
PostPosted: Fri Oct 23, 2009 9:54 am
Well, a trojan is not a virus, which means that it doesn't spread by itself. And I didn't put it in there, so I'm pretty sure that it's a false positive. It's not the first time that that has happened... The fact that only 2 scanners find it would also indicate that.
But, if you don't want to install this version 4.21 (which I can imagine), you could use the work-in-progress version listed on the following thread: viewtopic.php?f=6&t=644&start=110
I had never heard of VirusTotal, but I'll use it from now on before releasing new versions!
I expect to have a new version (4.22) ready by the end of this weekend.
Edit: AdAgent... So it's adware, not a trojan. Those also don't spread automatically.
PostPosted: Fri Oct 23, 2009 10:17 am
Thanks for the prompt reply.
Well, trojan, virus or adware - I dont like nasty things on my PC so was worried.
Anyway, if you say you have not put anything into the files then of course I trust you and it must be a false positive.
VirusTotal is a great website and something I advise everyone to use. The limit of 10mb aplies to any files uploaded but it does seem to give accurate readings and I also agree that with just 2 giving warnings it does suggest a false positive.
I will go ahead and install the software as have been looking forward to trying it.
Cheers hvz :-)
