Going to be running Stereo Tool inside a PC environment to feed a stream and then LPFM. Will will most likely be feeding it from a Sound Devices USB pre 2. What inexpensive or free patching software would you suggest I use to allow more ins and outs inside the PC running Windows 10?
Ideally I'd be able to direct the sound card input to Stereo tool and also switch the Stereo Tool input to the mix inside the computer when running automated.
Found this forum post from 2013 that seems to offer a good solution called VB-Audio. Is that one of the better solutions?
viewtopic.php?f=4&t=4911
Thanks for guidance. Sean
Broadcast Voiceover Talent
http://www.SeanCaldwell.com
