PostPosted: Thu Aug 08, 2013 6:48 pm
Thanks for your help.
I think it will send the audio to the transmitter without any process plant.
We play pop music, dance, I'm very few songs that we issue, which sound slowly.
Also the pc I use to issue not powerful enough to use Declipper (which I get in the future).
Another query, RadioBOSS includes another feature called ReplayGain (which is present in several players and programs), as I have understood, this sets gain before starting a song and not cause the sound level during playback.
It would also be advisable to disable this?
PostPosted: Sat Aug 10, 2013 12:49 am
No ReplayGain is good, since it adjusts the level of complete tracks without changing the sound. So turn that on, it makes things easier and it should also completely fix the streaming issue that you mentioned (too soft audio).
PostPosted: Sat Aug 10, 2013 1:15 am
Yes.. but "reply gain" is applyed before processing.. so only thing is - enough range in AGC.
Also for proper preset not needed.
PostPosted: Sun Feb 28, 2016 4:19 pm
I know that this is old thread but I would like to know is there any UECP Plugin for RadioBoss?
