PostPosted: Sun Sep 09, 2018 5:59 am
Any Idea why I can't seem to save my settings?
Using the stand alone version 8.54 on a MacPro tower running OS 10.7.5. With megaseg and Nicecast.
I'm still testing and evaluating so I have the unregistered version as I decide which features I would like. I am running the auto eq and the Natural dynamics (unregistered) and I am wondering if that's why I can't save?
I'm really happy with the settings I have now and want to save them because I'm planning on updating the OS to El Capitan (the most updated my old tower can handle)
Done all the standard save function options and it looks like they are saving, but when I look there are no sts files saved anywhere.
I guess my question would be then. If you have unregistered options as part of your set up can you save your settings?
Thanks
Gary Lee
khit107radio
