 Post subject: StereoTool VST & OBS
PostPosted: Wed Feb 21, 2018 10:11 am
Hello,
I'm currently trying to get StereoTool VST to work with OBS (https://obsproject.com) on Mac OS.
I install the 32-bit VST plugin to /Library/Audio/Plug-Ins/VST/, and it shows up in the list of plugins in OBS. However, the button "Open Plug-in interface" doesn't do anything.
Let me know if you've tried this before, and if there's any tricks you found.
Thanks,
Anthony.
Anthony Eden
https://mediarealm.com.au/
 Post subject: Re: StereoTool VST & OBS
PostPosted: Wed Feb 21, 2018 10:29 am
The OBS error log says "Couldn't get a pointer to plug-in's main()"
Anthony Eden
PostPosted: Wed Feb 21, 2018 11:32 pm
For what it's worth, it seems to function correctly in OBS Windows 64-bit. I'm unsure if this is an issue with StereoTool, or OBS - but other plugins seem to work on Mac OS, so I'm leaning towards StereoTool.
Anthony Eden
PostPosted: Thu Feb 22, 2018 1:46 pm
Hi Anthony,
I just installed OBS to try the same thing. The 32 bit plugin gives the same result. However the 64 bit plugin works properly :)
Apparantly OBS is 64 bit, but it shows the 32 bit plugin although it shouldn't.
Does the 64 bit version work for you as well?
