PostPosted: Mon Apr 17, 2017 2:34 pm
I've been able to use StereoTool with Jack on Ubuntu 16.04 LTS without any issues. I've disabled PulseAudio in order to get Jack to work. When I try to start StereoTool 8.30, I see this error and StereoTool does not start. Jack is running and holding onto ALSA directly. I need to Jack to feed the output of VLC and to connect a silence detector.
Thimeo Stereo Tool 8.30 (for Linux with Jack) (C) Hans van Zutphen, 2001-2017
ALSA lib pcm_dsnoop.c:606:(snd_pcm_dsnoop_open) unable to open slave
ALSA lib pcm_dmix.c:1029:(snd_pcm_dmix_open) unable to open slave
ALSA lib setup.c:548:(add_elem) Cannot obtain info for CTL elem (MIXER,'IEC958 Capture Switch',0,0,0): No such file or directory
ALSA lib pcm.c:2266:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi
ALSA lib pcm.c:2266:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
ALSA lib pcm.c:2266:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
ALSA lib pulse.c:243:(pulse_connect) PulseAudio: Unable to connect: Connection refused
Is there a command-line option to force Jack-Only mode?
Thanks.
Brian
PostPosted: Sat Apr 22, 2017 5:03 pm
Try the other download. I have 2 versions on the download page, 1 for ALSA and 1 for Jack.
