If one plays older music, which is still available on records, then clicks and scrapes it. The music could be adjusted before playback in Adobe Audition or using another restoration program. Sometimes you do not digitally available music. Then simply use the right turntable. This way you can still play the music yes. This again adds click and clack sounds.
Would it be possible in Stereo Tool might create the opportunity to eliminate click and clack noises? Adobe Audition has for a live-capable plugin, which has only two controls.
https://helpx.adobe.com/audition/using/ ... ver_effect
It must also not be removed all but the most obvious.
That would be really awesome if you could integrate such a thing.
