 Post subject: Singleband before MB1
PostPosted: Mon Mar 07, 2016 7:17 am
It would be nice if the SingleBand could be, by option, put before the MB1.
Is this possible Hans?
Regards,
Luc
Vrijwilliger bij ZuidWest FM / ZuidWest TV
PostPosted: Mon Mar 07, 2016 8:16 am
I would like to have a SB before the EQ. Yes, I could use the post-AGC-SB for that but because I don't use the ST-AGC (I use an external AGC before ST) it's both performance- and setting-wise quite a hassle. So having a SB before MB1 *and EQ* would make my life much easier. Would be a very welcome change!
PostPosted: Wed Mar 09, 2016 3:54 pm
Why would you want a wideband compressor before the MB if you're not even using the built in AGC ?
PostPosted: Thu Mar 10, 2016 1:03 am
There IS singleband compressor before MB1 (after AGC) with SC EQ.
PostPosted: Thu Mar 10, 2016 2:04 pm
I don't understand. Using a wideband compressor with built-in AGC is OK, but using it together with an external AGC is forbidden? Why?
Yes and I'm using it. Would be convenient and more efficient however, if it could be decoupled from the AGC, e.g. if AGC is off, work like the usual singleband compressor with absolute threshold. If it isn't woven into the AGC, that would be just a case distinction.
