PostPosted: Sun Feb 14, 2016 7:29 pm
I personally would have liked Stereotool to enable the users to arrange the single processor modules as often they like and in the order they like - much like you are able to do with VST plugins in music processing software. In WaveLab you can put several instances of Stereotool-VST behind each other and process music with variable processor settings multiple times/different order if you like. It would be cool if you can do that in Stereotool itself. It gives much more flexibility and the variation of possible settings explodes to the infinite (especially if you could combine each processing module with a bandpass filter, so each module would only process a certain area of bands and leave everything else as it is after the module).
