PostPosted: Sun Jan 04, 2015 10:35 pm
Hello,
I wish to be changed the following things:
AGC:
Can you make the option "prepare for BS412" accessable even when the BS412- limiter is turned off?
Reason: If you have a splitted processing with one processor before STL and the other (incl. Szereo encoder) at the transmitter, there is at the moment no way to "prepare the AGC at the studio side for BS412.
Compressors:
Can you make the gates more aggressive, so that the release speed is slowed *really* down, so that the compressors in gated condition need approx. 30 seconds to return to 0dB or so...
This is meant for the post-AGC- Compressor, the Singleband as well as the multiband compressors.
Thanks!
Kind Regards,
Robert
