PostPosted: Thu Oct 30, 2014 10:19 pm
As the title says :) I'm rather happy with the software and its functionality, but:
1. Loudness monitor in LUFS/LKFS is definitely missing and I think that many of us would use it.
2. Another thing is a built-in fully functional MPX demodulator (not just deemphasis) which also could help a lot if you want to check what your sound would be using an actual FM tuner.
3. Tweakable GUI with a possibility of modifying default color scheme.
4. Interactive block diagram (built into GUI) - with sub-menu call-out that would appear when certain module (e.g limter) is highlited. This would help to understand what and when actually happens to the audio. Accessing certain block would be easier this way too (I know it is somehow implemented, but that's not exactly it).
5. Last but not least - improved remote control, with full GUI support.
Regards,
Slawomir
PostPosted: Fri Oct 31, 2014 2:14 pm
+1 and a ITU bs1770-3 loudness controller (loudness based processing)
My radio station
http://amradio.ddns.net
