 Post subject: CPU usage Display
PostPosted: Fri Mar 21, 2014 1:22 am
Display CPU usage %. System Text. Place on on some visible place (top right for example).
Font can be White or green and when reach some high point, red.
 Post subject: Re: CPU usage Display
PostPosted: Thu May 01, 2014 2:34 am
And in addition to that , show the CPU load per core because it is not equal divided( the notorious composite clipper which only seems to use 1 or 2 threads ))
I have a tuned Core I5 capped & 2,4 GHZ and i have undervolted the CPU because of power saving , my whole Stereotool + playout system uses only 27 watts out of the socket.
But because i have capped al cores @ 2,4 GHZ i only can run the composite clipper @ 18 cpu strictness( no turbo boost per core because of undervolting )
Test stream OGG
Test stream FLAC
