 Post subject: Click and Enter
PostPosted: Mon Aug 19, 2013 5:52 pm
When entering numerical values, it would sometimes be much easier if you could enter it from the keyboard. It if you just click in a field, the color is changed and you can enter a value. With the tab, you can switch to the next field. The Enter key is used to validate the values. Ctrl + Tab to change the view using the tabs on the left.This allows pure keyboard operation. That would be really great if this would work!
