PostPosted: Fri Apr 12, 2013 1:13 pm
Hello,
To better see how high the power level is at the moment it would be good if you couldt insert a bargraph meter witch shows the "momentary" power, a value integrated about a user-adjustable time between 1s and 30s.
Furthermore it would be good to have a second meter witch shows you the metering over a very long time, adjustable until 2 hours or so.
So you are able to see the average level helping you to adjust the drive correctly.
Thank you for reply...
Regards,
Robert Sack
