PostPosted: Thu Feb 02, 2023 6:22 am
The idea is that each band in AGC (when there are 2 or more bands, obviously), has an independent Release Gate control. Perhaps this would help in part to prevent one of the bands, since it does not enter enough audio signal, from starting to release, especially when the threshold of each band is different, allowing the AGC to be more stable and consistent.
Best regards from Chile.-
PostPosted: Thu Feb 02, 2023 6:58 am
It's already there. MB > Gating. "Gate slowdown" and "Gate freeze". Additionally, there is "move to target on silence" with theresholds and speeds.
PostPosted: Fri Feb 03, 2023 4:35 am
Ehmm... yes, it's there, but I use: AGC -> To level at slow speeds + MB1 -> fast compression speed + MB2 -> Limiter. Based on what you say, I would have to use MB1 as AGC and MB2 as compressor/limiter.
PostPosted: Fri Feb 03, 2023 7:27 am
Ah, sorry, my bad. I dont know how i read that MB.
PostPosted: Fri Feb 03, 2023 9:10 pm
Don't worry dear Bojcha. I've been listening to your control point and it sounds amazing! It's very close to the sound I want.
