PostPosted: Sun Sep 23, 2018 3:03 am
I'm often dealing with rather dodgy taped sources, and they tend to lack in stereo balance.
It's almost always the left side missing a bit of volume and top from cassettes, but sometimes it's the opposite, and I have been extreme-tweaking stereotool to look for some hidden setting to make AGC and AutoEQ work like two mono processors, or some percentual stereo unlinking atleast.
In the Sound-section of AutoEQ there was a halfway solution with the Channel-linking setting, but it didn't come all the way to smootly balancing the stereoimage of a degraded tapesource. Maybe I dont understand exacly what that does, but I did get a bit more top on my bad sides when setting the three top bands to 99dB.
PostPosted: Wed Sep 26, 2018 6:59 pm
these is channel linking adjustment on both the current version and the deprecated version of the AGC (higher dB levels = better channel separation).
perhaps you are not seeing it if "extreme tweaker" is not selected in configuration - also, checking "show deprecated settings" shows more settings.
