PostPosted: Fri Jun 15, 2018 6:03 pm
Hello Hans... I think my question here will echo a similar question about having a UI Meter only display. This is tied in with the to-do list for v9 beta 90, where it says "GUI-Hide disabled stuff. Less confusing". My question is, would it be possible to make it so that disabled features would completely disappear from the main metering window, leaving only the enabled meters and features? What that would mean is that when any feature is disabled, the rest of meters currently active and visible would automatically draw out and expand to fill in the empty spaces. This would seem to simplify the main window when looking at it, seeing only the currently running meters instead of grayed out boxes. Maybe in a a future build that would be possible? Thank you.
