 Post subject: RDS Custom Data Groups
PostPosted: Tue Mar 20, 2018 2:45 pm
Hi I was wondering if you could add support for expert users to be able to define their own RDS Data Groups it would realy come in handy because we could brodcast TMC without Stereo Tool supporting it or add PIN or Radio Paging without naging you on forums for obscure features that only couple of people want and you don't want to add them (PIN, RP and more)
PTYN has been added in the latest beta Thanks hans
PS: can I use it from telnet with (PTYN=Balkans) command?
for instance this guy added RT+ support without his RDS Encoder supporting it: https://mediarealm.com.au/articles/rds- ... lus-setup/
many RDS Encoders have that including Airomate, 2wcom, and our beloved PIRA (Its beloved because of RDS Spy and MagicRDS at least for me)
and you could addopt Pira32 standard of putting RAW group data in telnet with G=GROUPS_AND_THEIR_HEX_DATA command
http://pira.cz/rds/manual.pdf on section 15.3 page 55
Thanks for Anwsering and Best Regards
PostPosted: Thu Mar 22, 2018 11:42 am
This would be a nice feature!
If Hans wants to make it simply, he could do it so that you'd have a choice to input a whole table of groups and data, so you could have total control of the RDS data. Otherwise the normal basic RDS controls would apply.
