So this isn't a huge issue. Just kinda noticed it, but when a song changes in Winamp, ST's screen update will show a full frame rate (looks very nice, and fast), but after a few seconds its like the framerate drops and the display of ST almost looks as if the screen updates was turned down. It's set to max and it doesn't matter if I change the bar down and then back up it still lags a bit until song change, or first run for about 10-20 seconds. My PC is for sure fast enough. Its that new Intel Q6600 Quad Core with 4GB Ram and fast SATA2 drives. CPU is average 15% usage. Thanks for any help. Like i said this can be put on the bottom of your list to fix.
Thanks.
-n4-
Update: The Screen Update slider is not working at all. The screen update speed remains the same look from 0-100% other than what I explained up top. Oh, and this is ST 6.30 DSP release.
