hi..
You should use soundcard synchronization. Set it ON. Buffer bar (blue) should always be around half.
This is not that (and Auto works fine for synchronization, it compares the sound card names - if it's the same one it's switched off, otherwise on).
But playing at a very slow speed while the buffer is 100% full would not be caused by this. That sounds more like the FM sample rate - which should be 176.4 or 192 kHz for FM - was somehow set to 44.1 or 48 again, without Windows (which would normally resample; you would loose stereo/rds but not get slow audio if that would ever happen) or Stereo Tool being aware of this. I've seen this happen on some ESI cards, and there it's obviously a driver issue (you can actually see in the ESI overview screen that the sample rate is not what it should be).
Edit: If you also make the sound cards restart if the buffer gets above 185% or something like that, it would at least restart if this ever happens again.
