PostPosted: Tue Jun 07, 2016 3:32 pm
I just tried to update VLC and noticed I had to close Stereo Tool to make it work. This happened the time before I updated VLC, but I forgot to tell you. Is this normal?
PostPosted: Tue Jun 07, 2016 4:31 pm
If you're running VLC streaming in Stereo Tool, then yes. Otherwise I'm not sure...
PostPosted: Tue Jun 07, 2016 4:51 pm
I was in bypass.
PostPosted: Wed Jun 08, 2016 2:11 pm
Ok but that doesn't necessarily mean that it's not using VLC.
