Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 587 posts ]  Go to page Previous 132 33 34 35 3659 Next
PostPosted: Wed Apr 06, 2016 7:00 am
+1
If I were a manager of a radio station, I would be a few dBs quieter than the loudest station on the dial to be just loud enough for dial-scanners to notice me and have enough dynamic headroom to form a signature sound.
Here is some advice from Leif Claesson (BBP, Omnia.9) regarding audio processing. The heading titles make no sense, but in my opinion the advice given is good.
Especially:
“Loudness is only important during the first 2 seconds. The first thing people do after they find a station that they want to listen to, is adjusting the volume”, Claesson knows. “Don’t kill your sound over that last dB of loudness. It’s not worth it. People will get tired of listening to the radio, without even knowing why. They’ll turn it off and listen to their iPod instead.” (A comfortable sound can help you to increase your Time Spent Listening.)
http://www.radioiloveit.com/radio-produ ... sing-tips/
PostPosted: Wed Apr 06, 2016 7:50 am
I would be a few dBs quieter...
I think you mixing up the things .
Loudnes means not the volume level - but the sound compression (how much the average power of the sound is close to 0 dB)
The volume level of sound you can regulate even at the receiver side , but this is not the thing we discuss in our discussion when we say "loudness".
In other words - the measurement with an ITU BS.1770 meter. If it shows higher level, this means higher compression.
PostPosted: Wed Apr 06, 2016 9:11 am
more/less. But be aware this 1770 not necessrily corresponds to loudness actually perceived by humans - I watched a straight line on the loudness meter in O.9 once - yet I could clearly notice differences in perceived loudness (especially in song build-up, when intro ended up slightly louder than the rest of the song).
PostPosted: Wed Apr 06, 2016 9:22 am
I know, but this was the closiest that i can explain for the person above , because he mixed up the feed volume level of transmitter and the the sound compression(loudness). You agree that you can make loud level in transmitter even with not compressed sound , right ?
This was only to tell this person that he means one, we mean other thing when we say "loudness".
That is why i make the example with that meter
PostPosted: Wed Apr 06, 2016 11:48 am
7.85 BETA054
Windows stand alone: http://www.stereotool.com/download/ster ... 85-054.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 85-054.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 85-054.dll
CHANGED:
- Absolute Highs: CRASH!
- Add Quadrature monitoring
- SPA remove monthly popup
- Added other optimizations
- Fix crash in BETA036.
- Exciter: Add Volume slider
- Exciter: Add DIFF mode
- Fixed crash when closing
- GUI: Added tooltips!
- Make scope skinnable
- "Bass AGC (Old)" panel
- "Classic Singleband" panel
- Delossifier: Lay Down breaks Delossifier, sounds really bad! (And it's not MP3). More accurate detection (smooth rolloff??) still needed, to also not detect it when not using Detect MPEG mode! Detection and reconstruction both fail! -> Better now, but: 1. Make sure that this doesn't reduce repair elsewhere (some other parts are better now too, so be careful with that!). Maybe only remove narrow 'gaps' in the xmul array. 2. Improve detection to make Lay Down sound good always. It's not even an MP3! Check not only close to border but also a bit higher - should be nearly perfect silence! Maybe also some slowness in starting to repair?
- Add 9sg link - how?
7.85 but after NAB:
- Absolute Highs: Optimize performance: Check log()
- Absolute Highs: Check how slowly the frequency should rise. Probably should only be available if Delossifier freq responds slowly?
- License check
- set Encryption : impossible to view or modify all the processing settings
- Preset Licensing : encrypted preset without beeps unlocked by a license
- Exciter: Try to reduce pre-ringing (maybe by doubling overlap? Or measure on bigger block size, then go back to smaller?) Is this still a problem?
LATER:
- O skin
PostPosted: Wed Apr 06, 2016 9:10 pm
Issue with last vst version used in Wavelab:
Choosing configuration tab will crash stereotool.
Other tabs seems to work but it make no sense to continue as I have no possibility to enter my license key.
PostPosted: Thu Apr 07, 2016 1:24 am
Last time when I compared the difference appeared to be in the singleband compressor that you were using at the end. Can you try what happens if you disable that?
Yes, when I disable the single band compressor, the distortions disappear!
I hope it is going to be fixed. I played around with the new single band compressor for an hour and failed to recreate the sound of the old one.
BTW the piano sample I posted distorts heavily super quick when pushed loud even with the new single band, while with the old single band with 7.03 I can push the sound very loud and the distortions appear very mild. To me the old single band seems in general better regarding distortions!? Or the distortions are a problem that comes with the new single band that the old one suffers too as result.
PostPosted: Thu Apr 07, 2016 6:16 am
7.85 BETA055
Windows stand alone: http://www.stereotool.com/download/ster ... 85-055.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 85-055.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 85-055.dll
CHANGED:
- Delossifier: Added MP3 detection filter; turn it on to disable the Delossifier when it thinks that the input is not an MP3.
- Delossifier: Protection added to not add too much. The result sounds cleaner, but it might also be slightly less effective. In total I think it's better.
- Detection and reconstruction both fail in 60's song Lay Down! -> Better now, but: 1. Make sure that this doesn't reduce repair elsewhere (some other parts are better now too, so be careful with that!). Maybe only remove narrow 'gaps' in the xmul array. 2. Improve detection to make Lay Down sound good always. It's not even an MP3! Check not only close to border but also a bit higher - should be nearly perfect silence! Maybe also some slowness in starting to repair?
- Delossifier: Lay Down breaks Delossifier, sounds really bad with MP3 detection turned off! (And it's not MP3). More accurate detection (smooth rolloff??) still needed, to also not detect it when not using Detect MPEG mode! Does Alternative Method sound better now?? Also try without HACK.
- Normal Output: Don't output FM anymore!
7.85 but after NAB:
- License check
LATER:
- O skin
PostPosted: Thu Apr 07, 2016 6:43 pm
I cannot access the configuration menu in the latest version. When I click on it, then freezes everything, and I have to close the client. It simply responds nothing.
PostPosted: Thu Apr 07, 2016 6:46 pm
Which version? (Winamp, VST, stand alone?)
