A bit of a bug, constant clicking with the VST version. Doesn't occur in the previous version of 7.70 just the newer 7.72
Software Environment:
Windows 10 Pro (64-bit)
Foobar2000 using VST Wrapper (tried using VST Adapter didn't make the clicking go away nor did changing anything else did)
ReplayGain (album) -10db with and -20 db without
DSP Chain:
- Pregap (delays for automated for playout, often disabled during testing)
- Convert mono to stereo (mono upmix)
- Matrix Mixer + Dynamic DSP + Downmix AC3/DTS (Surround Sound Management Scheme Using File Tags encodes Dolby Pro Logic II when Surround material is played)
- Advanced Limiter
- Downmix channels to Stereo (surround fail safe for unknown channel configurations and lack of information on how to encode them properly)
- Advanced Limiter
- Resampler (SoX) (upsamples to 192 KHz)
- Advanced Limiter
- Stereo Tool VST
Planned Output for future broadcasts: Wasapi Asus Phoebus Speakers (Event) 24-bit (max. buffer)
Current Testing Output: DS: Primary Sound Driver (1 second buffer)
Hardware Environment:
1 TB Hard Drive
4 GB RAM
1366 x 768 (screen resolution)
AMD Radeon HD Onboard Graphics
AMD Athlon II X2 220 Processor @ 2.81 GHz
ASUS CM1630 (OEM Motherboard)
ASUS PHOEBUS in PCI Express slot[/size]
